How to Install Automad CMS with Apache and Let’s encrypt on Debian 10
page1 28
Automad is a free, open-source and flat content management system written in PHP language. It is fast, responsive and offers features that may not be available to other PHP based CMS. Automad uses a text file to store its content instead of a database. Automad provides a web-based interface for managing site, system settings, upload images and write a blog post. It ships with a built-in Markdown editor and one-click updater to keep your Automad up-to-date.
In this tutorial, we will show you how to install Automad CMS on Debian 10 using Apache web server.
  • A server running Debian 10.
  • A root password is set up to your server.
apt-get upgrade -y
Install Apache and PHP
Automad is based on PHP and runs on a web server. So you will need to install Apache, PHP and other required modules to your server. You can install all of them by running the following command:
apt-get install apache2 php libapache2-mod-php php-zip php-curl php-mbstring php-gd php-xml php-xmlrpc php-soap unzip -y
Once all the packages are installed, start Apache web server and enable it to start on system reboot with the following command:
systemctl start apache2
systemctl enable apache2
Install Automad
First, you will need to download the latest version of Automad from the Bitbucket repository. You can download it with the following command:
wget https://bitbucket.org/marcantondahmen/automad/get/default.zip
unzip default.zip
Next, move the extracted directory to the Apache web root with the following command:
mv marcantondahmen-automad-c241e88edc3c /var/www/html/automad
Next, change the ownership of automad directory to www-data and give proper permission with the following command:
chown -R www-data:www-data /var/www/html/automad
chmod -R 755 /var/www/html/automad
Configure Apache for Automad
Next, you will need to create an Apache virtual host configuration file to server Automad. You can create it with the following command:
nano /etc/apache2/sites-available/automad.conf
Add the following content:
DocumentRoot /var/www/html/automad
ServerName example.com
<Directory /var/www/html/automad>
Options FollowSymlinks
Require all granted
ErrorLog ${APACHE_LOG_DIR}/automadcms_error.log
CustomLog ${APACHE_LOG_DIR}/automadcms_access.log combined
Save and close the file, when you are finished. Then, check Apache for any syntax error with the following command:
apachectl configtest
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Syntax OK
Next, enable the Apache virtual host and rewrite module with the following command:
a2ensite automad
a2enmod rewrite
Finally, restart Apache web server to apply the configuration changes:
systemctl restart apache2
Access Automad
Automad is now installed and configured, it’s time to access Automad web interface.
Open your web browser and type the URL http://example.com. You will be redirected to the Automad site in the following screen:
Front page of Automad CMS
To create an Automad account, open your web browser and visit the URL http://example.com/dashboard. You will be redirected to the following page:
Create user
Move account file
Now, provide your desired username and password, then click on the Download Accounts File button to download the user registration form and copy it inside config directory:
mv config.php /var/www/html/automad/config/
Next, give proper permission to config.php file with the following command:
chown -R www-data:www-data /var/www/html/automad/config/config.php
Now, open your web browser and type the URL http://example.com/dashboard. You should see the Automad login page:
Login to your site
Now, provide your username and password, and click on the Log In button. You should see the Automad CMS default dashboard in the following page:
Your site in Automad
Secure Automad with Let’s Encrypt
First, you will need to install Certbot tool to download and install Let’s Encrypt free SSL for your website.
First, add the Certbot repository with the following command:
apt-get install software-properties-common
add-apt-repository ppa:certbot/certbot
Next, update the repository and install Certbot with the following command:
apt-get install certbot python-certbot-apache -y
Once installed, you will need to create a .well-known directory inside letsencrypt directory. You can create it with the following command:
mkdir -p /var/lib/letsencrypt/.well-known
Next, you will need to give proper permissions to letsencrypt directory. You can do it with the following command:
chgrp www-data /var/lib/letsencrypt
chmod g+s /var/lib/letsencrypt
Next, create a well-known.conf file with the following command:
nano /etc/apache2/conf-available/well-known.conf
Alias /.well-known/acme-challenge/ "/var/lib/letsencrypt/.well-known/acme-challenge/"
<Directory "/var/lib/letsencrypt/">
AllowOverride None
Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
Require method GET POST OPTIONS
Save and close the file. Then, enable the required modules with the following command:
a2enmod ssl
a2enmod http2
a2enmod headers
a2enconf well-known
Next, restart Apache service to apply all the configuration changes:
Now, install Let’s Encrypt free SSL for your domain example.com by running the following command:
certbot --apache -d example.com
First, you will need to provide a valid email address and agree to the terms of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/example.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/example.com-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/example.com-le-ssl.conf
Next, choose option 2 to download and install a free SSL certificate for your domain. Once the installation has been completed successfully. You should get the following output:
Redirecting vhost in /etc/apache2/sites-enabled/example.com.conf to ssl vhost in /etc/apache2/sites-available/
Congratulations! You have successfully enabled https://example.com
https://www.ssllabs.com/ssltest/analyze.html?d=example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/example.com/fullchain.pem
/etc/letsencrypt/live/example.com/privkey.pem
Your cert will expire on 2019-10-22. To obtain a new or tweaked
Your Automad CMS is now secured with Let’s Encrypt free SSL. You can access it by visiting the URL https://example.com.
