Bash Script for Loop Explained with Examples
Bash for Loop Explained with Examples
The for loop is an essential programming functionality that goes through a list of elements. For each of those elements, the for loop performs a set of commands. The command helps repeat processes until a terminating condition.
Whether you’re going through an array of numbers or renaming files, for loops in Bash scripts provide a convenient way to list items automatically.
This tutorial shows how to use Bash for loops in scripts.
  • Access to the terminal/command line (CTRL+ALT+T).
  • A text editor, such as Nano or Vi/Vim.
  • Elementary programming terminology.
Use the for loop to iterate through a list of items to perform the instructed commands.
The basic syntax for the for loop in Bash scripts is:
for <element> in <list>
do
	<commands>
done
The element, list, and commands parsed through the loop vary depending on the use case.
Bash For Loop Examples
Below are various examples of the for loop in Bash scripts. Create a script, add the code, and run the Bash scripts from the terminal to see the results.
Individual Items
Iterate through a series of given elements and print each with the following syntax:
#!/bin/bash
# For loop with individual numbers
for i in 0 1 2 3 4 5
do
   echo "Element $i"
done
individual.sh for loop script
Run the script to see the output:
. <script name>
individual.sh terminal output
The script prints each element from the provided list to the console.
Alternatively, use strings in a space separated list:
#!/bin/bash
# For loop with individual strings
for i in "zero" "one" "two" "three" "four" "five"
do
   echo "Element $i"
done
individual_strings.sh for loop script
Save the script and run from the terminal to see the result.
individual_strings.sh terminal output
The output prints each element to the console and exits the loop.
Range
Instead of writing a list of individual elements, use the range syntax and indicate the first and last element:
#!/bin/bash
# For loop with number range
for i in {0..5}
do
        echo "Element $i"
done
range.sh for loop script
The script outputs all elements from the provided range.
range.sh terminal output
The range syntax also works for letters. For example:
#!/bin/bash
# For loop with letter range
for i in {a..f}
do
        echo "Element $i"
done
range_letters.sh for loop script
The script outputs letters to the console in ascending order in the provided range.
range_letters.sh terminal output
The range syntax works for elements in descending order if the starting element is greater than the ending.
#!/bin/bash
# For loop with reverse number range
for i in {5..0}
do
        echo "Element $i"
done
range_reverse.sh for loop script
The output lists the numbers in reverse order.
range_reverse.sh terminal output
The range syntax works whether elements increase or decrease.
Range with Increment
Use the range syntax and add the step value to go through the range in intervals.
For example, use the following code to list even numbers:
#!/bin/bash
# For loop with range increment numbers
for i in {0..10..2}
do
        echo "Element $i"
done
increment.sh for loop script
The output prints every other digit from the given range.
increment.sh terminal output
Alternatively, loop from ten to zero counting down by even numbers:
#!/bin/bash
# For loop with reverse range increment numbers
for i in {10..0..2}
do
        echo "Element $i"
done
increment_reverse.sh for loop script
Execute the script to print every other element from the range in decreasing order.
increment_reverse.sh terminal output
Exchange increment 2 for any number less than the distance between the range to get values for different intervals.
The seq Command
The seq command generates a number sequence. Parse the sequence in the Bash script for loop as a command to generate a list.
#!/bin/bash
# For loop with seq command
for i in $(seq 0 2 10)
do
   echo "Element $i"
done
seq.sh for loop script
The output prints each element generated by the seq command.
The seq command is a historical command and not a recommended way to generate a sequence. The curly braces built-in methods are preferable and faster.
C-Style
Bash scripts allow C-style three parameter for loop control expressions. Add the expression between double parentheses as follows:
#!/bin/bash
# For loop C-style
for (( i=0; i<=5; i++ ))
do
   echo "Element $i"
done
cstyle.sh for loop script
The expression consists of:
  • The initializer (i=0) determines the number where the loop starts counting.
  • Stop condition (i<=5) indicates when the loop exits.
  • Step (i++) increments the value of i until the stop condition.
Separate each condition with a semicolon (;). Adjust the three values as needed for your use case.
The terminal outputs each element, starting with the initializer value.
cstyle.sh terminal output
The value increases by the step amount, up to the stop condition.
Infinite Loops
Infinite for loops do not have a condition set to terminate the loop. The program runs endlessly because the end condition does not exist or never fulfills.
To generate an infinite for loop, add the following code to a Bash script:
#!/bin/bash
# Infinite for loop
for (( ; ; ))
do
      echo "CTRL+C to exit"
done
infinite.sh for loop script
To terminate the script execution, press CTRL+C.
infinite.sh terminal output
Infinite loops are helpful when a program runs until a particular condition fulfills.
Break
The break statement ends the current loop and helps exit the for loop early. This behavior allows exiting the loop before meeting a stated condition.
To demonstrate, add the following code to a Bash script:
#!/bin/bash
# Infinite for loop with break
i=0
for (( ; ; ))
do
        echo "Iteration: ${i}"
        (( i++ ))
        if [[ i -gt 10 ]]
        then
                break;
        fi
done
echo "Done!"
break.sh for loop script
The example shows how to exit an infinite for loop using a break. The Bash if statement helps check the value for each integer and provides the break condition. This terminates the script when an integer reaches the value ten.
break.sh terminal output
To exit a nested loop and an outer loop, use break 2.
Continue
The continue command ends the current loop iteration. The program continues the loop, starting with the following iteration. To illustrate, add the following code to a Bash script to see how the continue statement works in a for loop:
#!/bin/bash
# For loop with continue statement
for i in {1..100}
do
        if [[ $i%11 -ne 0 ]]
        then
                continue
        fi
        echo $i
done
continue.sh for loop script
The code checks numbers between one and one hundred and prints only numbers divisible by eleven.
continue.sh terminal output
The conditional if statement checks for divisibility, while the continue statement skips any numbers which have a remainder when divided by eleven.
Arrays
Arrays store a list of elements. The for loop provides a method to go through arrays by element.
For example, define an array and loop through the elements with:
#!/bin/bash
# For loop with array
array=(1 2 3 4 5)
for i in ${array[@]}
do
        echo "Element $i"
done
array.sh for loop script
The output prints each element stored in the array from first to last.
array.sh terminal output
The Bash for loop is the only method to iterate through individual array elements.
The for loop can also be used to iterate through key-value pairs in associative arrays. For more information, refer to our guide on associative arrays in Bash.
Indices
When working with arrays, each element has an index.
List through an array’s indices with the following code:
#!/bin/bash
# For loop with array indices
array=(1 2 3 4 5)
for i in ${!array[@]}
do
        echo "Array indices $i"
done
indices.sh for loop script
Element indexing starts at zero. Therefore, the first element has an index zero.
indices.sh terminal output
The output prints numbers from zero to four for an array with five elements.
Nested Loops
To loop through or generate multi-dimensional arrays, use nested for loops.
As an example, generate decimal values from zero to three using nested loops:
#!/bin/bash
# Nested for loop
for (( i = 0; i <= 2; i++ ))
do
    for (( j = 0 ; j <= 9; j++ ))
    do
            echo -n " $i.$j "
    done
  echo ""
done
nested.sh for loop script
The code does the following:
  • Line 1 starts the for loop at zero, increments by one, and ends at two, inclusive.
  • Line 3 starts the nested for loop at zero. The value increments by one and ends at nine inclusively.
  • Line 5 prints the values from the for loops. The nested for loops through all numbers three times, once for each outer loop value.
nested.sh terminal output
The output prints each number combination to the console and enters a new line when the outer loop finishes one iteration.
Strings
To loop through words in a string, store the string in a variable. Then, parse the variable to a for loop as a list.
#!/bin/bash
# For loop with string
strings="I am a string"
for i in ${strings}
do
        echo "String $i"
done
string.sh for loop script
The loop iterates through the string, with each word being a separate element.
string.sh terminal output
The output prints individual words from the string to the console.
Files
The for loop combined with proximity searches helps list or alter files that meet a specific condition.
For example, list all Bash scripts in the current directory with a for loop:
#!/bin/bash
# For loop with files
for f in *.sh
do
        echo $f
done
files.sh for loop script
The script searches through the current directory and lists all files with the .sh extension.
files.sh terminal output
Loop through files or directories to automatically rename or change permissions for multiple elements at once.
Command Substitution
The for loop accepts command substitution as a list of elements to iterate through.
The next example demonstrates how to write a for loop with command substitution:
#!/bin/bash
# For loop with command substitution
list=`cat list.txt`
# Alternatively, use list=$(cat list.txt)
for i in $list
do
        echo $i
done
command.sh for loop script
The Bash comment offers an alternative syntax for command substitution. The code reads the contents of the list.txt file using the cat command and saves the information to a variable list.
command.sh and list.txt terminal output
Use the command substitution method to rename files from a list of names saved in a text file.
Note: Learn how to use the cat command and for loop to read files line by line in Bash.
Command Line Arguments
Use the for loop to iterate through command line arguments.
The following example code demonstrates how to read command line arguments in a for loop:
#!/bin/bash
# For loop expecting command line arguments
for i in $@
do
    echo "$i"
done
arguments.sh for loop script
Provide the command line arguments when you run the Bash script.
. <script name> foo bar
arguments.sh terminal output
The $@ substitutes each command line argument into the for loop.
After following this tutorial, you know how to use the for loop in Bash scripts to iterate through lists.
Next, learn how to write and use Bash functions.
