Bash printf – How to Print a Variable in Bash
Bash printf - Learn to print a variable in Bash.
The bash printf command is a tool used for creating formatted output. It is a shell built-in, similar to the printf() function in C/C++, Java, PHP, and other programming languages. The command allows you to print formatted text and variables in standard output.
Use printf in bash scripts to increase efficiency and reusability when programming.
In this tutorial, you will learn to use the printf command in Linux to print variables and format the output.
Bash printf - Learn to print a variable in Bash.Bash printf - Learn to print a variable in Bash.
  • A machine running Linux
  • Access to a terminal (Ctrl + Alt + T)
Note: Another way to print variables and strings in the terminal is to use the echo command. However, while echo has few or no formatting options, printf facilitates and offers many text formatting options.
Bash printf Syntax
The printf command accepts the following syntax:
printf [-v var] [format specifiers] [arguments]
[-v var]
The optional -v flag assigns the output to the [var] variable instead of printing it in standard output.
[format specifiers]
Format specifiers are strings that determine the methods of formatting specifiers. The following section includes a list of accepted specifiers.
[arguments]
Arguments can be any value or variable, and the [format specifiers] point to the [arguments]. If there are more arguments than format specifiers, the format string is reused until it interprets the last argument.
If there are fewer format specifiers than arguments, number formats are set to zero (0), while string formats are set to null (empty).
Note: Learn more about the awk command, a Linux tool for data processing and manipulating that produces formatted reports.
printf Specifiers
The following table shows common printf format specifiers and their descriptions:
Format Specifier Description
%c Treat the arguments as a single character.
%d Treat the input as a decimal (integer) number (base 10).
%e Treats the input as an exponential floating-point number.
%f Treat the input as a floating-point number.
%i Treat the input as an integer number (base 10).
%o Treats the input as an octal number (base 8).
%s Treat the input as a string of characters.
%u Treat the input as an unsigned decimal (integer) number.
%x Treats the input as a hexadecimal number (base 16).
%% Print a percent sign.
%Wd Print the W integer X digits wide.
%(format)T Outputs a date-time string resulting from using format as a format string for strftime. The corresponding argument can be the number of seconds since Epoch (January 1, 1970, 00:00), -1 (the current time), or -2 (shell startup time). Not specifying an argument uses the current time as the default value.
n Prints a newline character.
t Print a tab character.
Some format specifiers accept format modifiers that modify their actions. Enter the modifiers between the % character and the character that specifies the format.
Available format modifiers are:
  • <N>. Enter a number that specifies a minimum field width. If the output text is shorter, it’s padded with spaces. If the text is longer, the field expands.
  • . (dot). When used with a field width modifier, the field doesn’t expand for longer text. Instead, the text is truncated.
  • -. Left-aligns the printed text. The default alignment is right.
  • 0. Pads the numbers with zeros instead of spaces.
  • <space>. Pads a positive number with a space, and a negative number with a minus (-).
  • +. Prints all numbers signed (+ for positive, - for negative).
  • '. For decimal conversions, applies the thousands grouping separator to the integer portion of the output according to the current LC_NUMERIC file.
Note: Learn to set environment variables in Linux.
Bash printf Examples
The examples below demonstrate common use cases and different ways of formatting output using printf.
While the command can print variables in the terminal, it is more beneficial to use it in bash scripts as they allow code reuse and facilitate automation.
Separate Output with a Newline Character
Unlike echo, using printf to print a string or variable without any format specifiers outputs the unformatted text in a single line. To add a newline character and separate the entries, specify the n format specifier:
Separate printf output entries with a newline character.Separate printf output entries with a newline character.
A newline character now separates the printed output.
Use printf to print multiple variables in standard output. Follow the steps below:
1. Open the terminal (Ctrl + Alt + T) and create a bash script using a text editor such as vi/vim:
vi script.sh
2. Enter the following lines:
#!/bin/bash
printf "Enter your name:n"
read name
printf "Enter your surname:n"
read surname
printf 'Welcome: %sn' "$name $surname"
The %s in the format string points to the variables defined in the previous lines, while n instructs printf to add a newline character.
3. Save the script and exit vi by entering:
:wq
4. Run the script:
bash script.sh
5. Input the requested values for the two variables and check the result:
Print multiple variables in Bash using printf.Print multiple variables in Bash using printf.
The printf command stores the input in the two variables and then prints the variables in standard output.
Automatically add dynamic padding or change the variable output alignment using printf. Follow the steps below to print a variable in a mock table:
1. Create a script file:
vi table.sh
2. Enter the following lines and save the script:
#!/bin/bash
var='hello'
printf '|%10s|n' "$var"
The %10 ensures there are ten characters within the pipe symbols, padding the variable output with whitespace characters to that length. The s treats the input variable as a string.
3. Run the script and check the result:
bash table.sh
Create a mock table using printf.Create a mock table using printf.
The command outputs the variable encased in pipe symbols and aligns it to the right by default. To align the output to the left side, add the - modifier after the % character in the format string:
#!/bin/bash
var='hello'
printf '|%-10s|n' "$var"
Change text alignment in printf output.Change text alignment in printf output.
Add Decimal Points
Use printf with the %f format specifier to treat the input as a floating-point number and add the precision of two decimal places. Follow the steps below:
1. Create a bash script:
vi precision.sh
#!/bin/bash
printf "Enter a decimal number:n"
read number
printf "%5.2fn" "$number"
3. Run the script:
bash precision.sh
Round a number to two decimal places.Round a number to two decimal places.
The output prints the variable as a floating-point number rounded to two decimal places.
Store Data in a Variable
Use the -v flag with printf to assign a shell variable to store the data instead of printing it in standard output.
vi variable.sh
#!/bin/bash
printf -v var 'Welcome'
printf '%sn' "$var"
3. Execute the script:
bash variable.sh
Store data in a variable instead of printing it to standard output.Store data in a variable instead of printing it to standard output.
The output prints the stored variable contents.
Note: Read our tutorial to learn everything about bash functions.
Convert Hexadecimal Numbers
The %d format specifier instructs printf to treat the input as a decimal (integer) number. Use the specifier to create a script that converts hexadecimal numbers to decimal ones.
vi convert.sh
#!/bin/bash
printf 'Enter a hexadecimal number:n'
read number
printf "%dn" "$number"
3. Run the script:
bash convert.sh
Convert hexadecimal numbers to decimal ones using printf.Convert hexadecimal numbers to decimal ones using printf.
The script converts the input hexadecimal number to a decimal one.
Convert Decimal Numbers to Octal
Use the %o format specifier to convert decimal numbers to octal numbers. Follow the steps below:
1. Create a script:
vi octal.sh
#!/bin/bash
read number
printf "The octal number of "$number" is %on" "$number"
3. Run the script:
bash octal.sh
Convert decimal numbers to octal ones.Convert decimal numbers to octal ones.
The script converts the inputted decimal value to an octal one.
Print Date
Create a script that utilizes printf to display the current date. Follow the steps below:
1. Create a script:
vi datetime.sh
#!/bin/bash
printf 'Today is %(%F)Tn' -1
The %F treats the input as a floating-point number, while -1 indicates the current date.
3. Run the script to check if it works:
bash datetime.sh
Print the current date and time using printf.Print the current date and time using printf.
The output states the current date and time.
Add Commas to Thousands
When dealing with numbers, use the ' modifier to make the output more readable by adding commas to denote thousands. Follow the steps below:
vi decimals.sh
#!/bin/bash
printf "Enter a number:n"
read number
printf "%'dn" $number
3. Run the script:
bash decimals.sh
Separate thousands with commas to improve readability.Separate thousands with commas to improve readability.
After entering a number, the script utilizes printf to add the commas to the input value automatically.
Get Character ASCII Code
Create a script that uses printf to output an input character’s ASCII value. Follow the steps below:
1. Create a script:
vi character.sh
2. Enter the following lines and then save the script:
#!/bin/bash
printf "Enter a character to get character code:n"
read character
printf "%dn" "'$character"
3. Execute the script and test if it works:
bash character.sh
Get a character's ASCII code with the printf command.Get a character's ASCII code with the printf command.
The script outputs the input character’s ASCII value.
This guide showed how to use the printf tool to print a variable in Bash and format the output using the available specifiers.
Next, learn to use the bash read command to split a file or input into different fields.
